Seatbelt light
Pr0jeCt
Hi, i have been trying to find information on this problem but with no luck.
i have a 91 240sx and the auto seatbelts work correctly.. only problem is the car doesnt think i have them on. In park or driveing the light will come on, chime, and go off eventually..if i move the light comes back on.
Besides the wire under the drivers seat leading up to the lap connector, is their any other wires for the seatbelt check system? how do i stop this from chimeing and lighting up.. its getting really annoying. Any help appreciated.. thank you.
Tech12
Car: 91 240sx Super Hicas
Welcome to the forum. Most likely problem is a failing electrical contact for the seat belt sensor. You could try taking your "female" buckle parts apart and give them a light sanding and cleaning them with alchy afterwards.
Also, at one point I bought this great stuff called electrical contact cleaner at radioshack. Works wonders with just a quick spray and wiggling the components together. It's suppose to help keep corrosion away too.
Good luck
Pr0jeCt
were talking the female part for the lapbelt..or the auto shoulderbelt?
From what i see the only electrical on these belts is in the lapbelt 'female' connector.. am i correct?
if so how well would cutting the 2 wires and twistin them together work out?
Tech12
I'm pretty sure mine dings for the shoulder, aka choker, belt. In theory, connecting the wires should work. If you wanted to test it, make sure you cut with enough wire on both sides to put them back together if it doesn't work
Pr0jeCt
cut the black wires under driver seat.. twisted em together.. still lightin up and dingin.
is their a sensor in the auto belt part for the seatbelt indicator? .
Pr0jeCt
Pr0jeCt
Pr0jeCt wrote:cut the black wires under driver seat.. twisted em together.. still lightin up and dingin.
Bump.. also could it be possable loose wires from seat to seatbelt module?
Pvt.Donut
I had this problem awhile agoo. It turned out whoever the previous owner of my car put a keyless entry and overtime it had a loose wire. so check all ur wiring in the doorpanel that goed intoo the latch.
and also if u cant figure it out on ur own. Nissan has LIFETIME warranty on these auto seatbelts. so u can get new rails and controller and seatbelt latch for ZIP.
krazy88
Car: 1989 240sx
I am not sure if its the same for nissan but when i had problems on my acura, someone mention seat belts being under life time warranty. Again im not sure, but its something to look into.
Pr0jeCt
Pvt.Donut wrote:I had this problem awhile agoo. It turned out whoever the previous owner of my car put a keyless entry and overtime it had a loose wire. so check all ur wiring in the doorpanel that goed intoo the latch.
i think i might look into that.. if i cant rig it to stop blinking.. why not let them fix it for free
