Seat Slide Motor Kit Where to get?
Ryman
Car: 2001 Infiniti QX4
my seat hasn't worked for a while and I just got the tsb on it and I did what it said to troubleshoot the problem and it applies to my seat. I called the dealership and they're going to charge me 700 for the part and labor and 450 for the part itself. I'm trying to look for it online, anyone know where to get it? It's supposedly part#: 87562-c9925 - seat slide motor kit
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
The part is $252.66 here.
asnorton44
I just installed heated seats from a 2003 in my 2001 so I have my original seats and the motors are good on both if your interested.
ARKQX33V6
Not to interfere with a sale, but these DC motors are cheap, in design, a possible fix is to check the motor out for working. If no work from the motor, check all wires especially the - ground. Then see if the motor has a set of carbon brushes, they may be stuck or too much carbon dust is misdirecting the DC to other parts of the motor. Clean lubricate and free up the brushes. If they are worn try a motor rewind shop for the same or bigger brushes and grind them down to fit.
Make sure the armature is good and commutator is undercut, round and clean.
The commutator has copper looking segments with spaces between, these spaces are mica insulators that need to be below the segments. When the commutator is worn the diameter is smaller and the segments and insulators are at the same level that that brushes make contact.
The brushes are semi-conductors and conduct when energized, but conduction is interfered with the mica insulator.
The motor are fractional HP but they produce torque through a gear head to move the seat. Max and min seat movement are limited so check the limits.
