Seat setting program
tmak26b
Car: 95 Q Boat
Hi,
I have tried to follow the manual to program the seats, but I don't seem to be able to recall or even save the seat setting. Can someone provide a qucik write up on how to do it and then recall it?
Thanks
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
It's been written up a couple of times. Did you fllow the manual explicitlly?
96Qowner
Car: 1996 Q45
I simply get the seat to where I want it and then push the center (save) button once, then hold down the 1 or 2 until it blinks. The trick is you have to hold that button longer than you think.
Here's a thread with more detail about various seat memory problems. Be sure to read the linked thread in goody's post:
zerothread?id=144178
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Make sure the Cancel button isn't pressed in, as it disables the memory function.
qship96
Car: 1996 Infiniti Q45
MinisterofDOOM wrote:Make sure the Cancel button isn't pressed in, as it disables the memory function.
Wrong! It only cancels automatic steering wheel/seat slide when inserting/removing key from ignition
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Isn't that disabling the memory of the auto positioner function while that switch is engaged?
qship96
Even with the automatic drive positioner function disabled{cancelled} the positions set in memory bank 1 &2{seat/mirror/wheel} remain stored and ready for use by pressing the desired one- just doesnt do the song and dance routine upon key insertion/removal
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Yeah, that's what I thought, the memory function is cancelled, but the data is still stored when the memory function is enabled again.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I could swear I wasn't able to SET seat program positions with Cancel "on." Use them, yes. Set them, no. Maybe it was just coincidence...
