Seat Problems
94Q45
Car: 1994 Q45
I have a 94 Q 2 days ago the seat buttons start blinking and my memory function has gone out the window? Need some help on this one. Yes i did try re programming the seat settings but no luck. Thanks in advance for any help!!!
poly
Car: J30t
Your OCS Module under the seat is fryed. It wont communicate with switch
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
The one in Lola has done that twice. I just disconnect the battery for 10 seconds or so, and re-connect it. The flashing stops, and I can reset the memory.
If the seat and wheel fail to go to the home position, when you open the door, insert the key, turn on the car, close the door, turn off the key, but dont remove it, wait about 2 minutes and open the door. The wheel and seat shoud go to the home position. If not try it again. You want to turn off the key all the way (push the button - but don't pull it)
94Q45
Car: 1994 Q45
Thanks Jeff i will try that tonight!!!!!
94Q45
Car: 1994 Q45
Jeff that worked thanks alot
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
The driver seat in my 1991 Q45 will not adjust with the switches on the door. If I put the key in, and then take it out, the steering wheel will go back to the the home position and the seat will go back but when I put the key back in, the seat will not come forward, nor can I adjust it with the controls. Only the steering wheel can be manually adjusted. What I ended up doing was inserting and removing the key until the seat was back as far as it would go. The seat will not respond to the control pad. Please help as now I am going on a trip this week to Tampa and can barely reach the pedals.
Thanks in advance,
Matthew DanielsJacksonville, FL
