Seat Problem...
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
The seat in my G35 Coupe is loose... you can rock it back and forth 1-2 inches... it's not safe and the car is not under warrenty anymore.. What do I do?
Gimli G35
Car: 1996 Lexus ES300
looks like time to get a new set of sparco seats ,
well what you can do is try to see if any of the bolts under the seat is loose , hopefully thats your culprit ( i cant spell - so any typos try to figure it out lol ) .. if thats not the problem , try to bring it back to the dealership , im unsure how much they would charge since its not warrantied
joe603
Car: 2014 Durango R/T
I wouldn't mess around with that one...if you cant see a bolt loose or something, take it to a dealer. It would suck if you were driving down the road and your seat gave out! It probably won't be that expensive....unless you need a new seat.
infinititech1
well damn...i had the thing to fix it a few months ago but no one wanted it so i threw it away. there is a bulletin on some of those. it the spring assembly that needs to be replaced under the seat
clawthat
Car: 2005 Infinity G35 6MT
There is a recall on the seat bracket. It is broken and they will have to order one because the dealers don't keep'em in stock. It happened to my 2005 coupe and they replaced it at No charge.
Good luck.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
The metal on the seat bracket snaped...
Return to “G35 and G37 Interior, Exterior and Audio”
