Lokim »
https://forums.nicoclub.com/lokim-u160520.html
Fri Sep 03, 2010 11:28 pm
The BCMs from the 94-96 Q's have a TSB issued addressing symptoms like yours. You probably need a replacement BCM. Do the seat/steering column controls work? If not, you are a classic TSB symptom. The TSB # is ITB96-016 and applies to vehicles w/ a build date prior to 12/5/95. Any BCM from a car w/ a production date after 12/95 should fix the problem. The updated BCM P/N is 28941-67U03. Good Luck!
