seat memory
monamh27
Car: 2001 nissan pathfinder
i have a 2001 pathfinder and i can't seem to set the seat memory for the power seats. the dealer showed me how to do it, but when i have to do iy myself, i can't do it. please help!!!!
Innovazn
Car: Yellow 1998 Nissan R34 Skyline RB25DET 5 MT - Current
White 2012 Nissan Altima Coupe 3.5SR 6MT - Salvage (T-Boned at left turn)
White 2002 Nissan Pathfinder LE - SOLD (blew the engine)
monamh27 wrote:i have a 2001 pathfinder and i can't seem to set the seat memory for the power seats. the dealer showed me how to do it, but when i have to do iy myself, i can't do it. please help!!!!
hold set, wait for both lights to go on. select one
and voila, there is also a switch on the left of the steering wheel that shows the "Seat" and "auto" make sure it is in the on position. and ensure you dont unplug the battery.
donald
Car: 2001 Infiniti QX4 (RIP, 2011)
2010 Pathfinder LE
ok - so I did this, but when I manually moved the seat out of position, it didn't do anything.
Did I set it right or did I miss something?
Here's exactly what I did:
1. moved the seat into my desired postition (recliner, fwd/bkwd, and tilt)
2. hold set button until (1) and (2) lit up
3. pressed (1); expecting (1) to save the current positions
4. manually moved the seat forward, as if a shorter person was driving the truck
5. pressed (1) - nothing happened
I made sure the seat-memory switch was not on "Off/cancel", but was set to "Auto".
Innovazn
intresting.... i dont know then dude. sounds like you did everything you should do. after hitting the 1 button did it flash momentarily? (2 should not be flashing or lit up at this point)
donald
2010 Pathfinder LE
I went to download the owners manual this morning here: http://www.infiniti-techinfo.com/deptog.aspx?dept_id=55
reading thru the manufacturer's instructions... I'm supposed to be in "P" or less than 4mph.
I was in neutral. I have the tendancy to slap the car in neutral when I'm parked in a parking spot (reasons are insignificant as to why - just habit).
So, I re-did all the instructions as Innovazn instructed while in "P" and it works now :)
Pathofinder
Car: 2001 Nissan Pathfinder 2wd Vq35De
I couldnt figure them out on my own either, good steps to know thanks!!
