PMF wrote:I have a question about the seat memory buttons... are they supposed to include the side mirrors? The buttons remember the seat position, but never move the side mirrors- are they supposed to ?
If the side mirrors have been moved, like say at a car wash or the dealer, pressing the memory button for YOUR setting,(usually#1) will return seat, steering wheel, and both mirrors to your preferred settings. So yes, the memory does move the mirrors, but only if they've been moved from the position your memory is set to.
Also, the tilt-down feature does not work if the mirror control is set to the middle position. IF you have set each mirror separately to the position you want when backing and have the control switch turned to the mirror you want to move for backing it will move the mirror in and down when you put the car into reverse, but only of you have the mirror control turned to the mirror that you want to move in/tilt down. When you take the car out of reverse, the mirror will automatically return to its original memory position. Each mirror must be set separately for the move-in/tilt down feature to work first (AFTER you have set the base memory position), and the mirror control must be set to the one you want to move. You can not move both mirrors simultaneously when backing, only the one you have the control turned to, and have already set it for this function.
Owner's manual explains it..
