It might be crazy, but your cancel button might be depressed. My Q guy told me he used to get tons of of Q's coming in because owner's inadvertently hit the switch, then came in and complained of a malfunction. They paid for diagnostics and drove loaners all around while the techs just pushed the cancel button again to reset.dfowler wrote:For some reason this feature isn't working anymore. I stopped after I got a Viper alarm with remote start installed. I wonder if something was was disconnected and needs to be re-connected. Anyone knows about this?
It's part of the same switch assembly as the joystick that controls the steering wheel. You should absolutely follow the reset procedure too... the 94-96 seems to need it from time to time.dfowler wrote:Where would the cancel button be located?
RTOM!dfowler wrote:Where would the cancel button be located?
1.) Strike a pose! No one here has run them. Refer to the tire sticky in Infiniti General. Educate us. Size? Load rating? Speed Rating? Construction? UTQG?dfowler wrote:1.) I have a question about Vogue Tyres? .... My question is are they really good for the 1994 Q 45.
2.) Also I was wondering about the suspension on the Q45a? Whats the difference? More suspension on the rear wheels or more expensive?
It's on the left side of the steering column and is part of the tilt switch. Depressing it cancels the memory so it needs to be off (button out). Did you try the reset procedure posted earlier? What were the results? After that you may have to reset the memory on the door.dfowler wrote:Where would the cancel button be located?
