Seat is stuck :help
S13D.W.A
Car: 1989 240sx Coupe
Well my seat belt on my 1989 240sx isn't moving does anyone know how to fix this problem?
Warped161
Car: 90 s13 the never ending project
um the upper or lower part, is it stuck in the track? a little more info.
S13D.W.A
The Upper side of the driver it moved foward but now wont come back to the back
Warped161
the seats are operated by the computer in your center console, try switching the connectors to see if it's a motor or cpu issue. you may have to open the pass door the get the driver belt to move once you switch the wires.
S13D.W.A
Okay I'll Try This And Let You Know What Haappens Thank You
S13D.W.A
I Opened the counsel and the plugs are different one is bigger than the other so what do i do know to switch them around?
Warped161
hmm crap, was afraid of that, o got rid of my whole setup and went with manual belts off the 95's, believe it or not i think nissan has some kind of crazy warranty on the seatbelt system, give a dealership a call in the morning.
S13D.W.A
Cool So How Did you swap the manuel belt from the s14 to your s13 i think that will be much more easier
Warped161
http://www.nicoclub.com/articles.php?id=215210i just got a set from a part out fore like 35 bucks
S13D.W.A
Cool Thanks Well I'm Going To Do That And Post Up Some Photos After When I'm Done With This Project :]
