Gerardjg »
https://forums.nicoclub.com/gerardjg-u36599.html
Fri Apr 14, 2006 2:31 pm
I just replaced the bulbs in both my switches Radio shack part number 272-1092 $1.50 for 2.
Remove the lower black part of the switch from the plug side(do not remove the switch rocker there are little springs and things in there)Once you get the switch opened inside are the contacts in a plastic assembly it can onlygo back one way. That is the only part in this side.
On the black plug section of the switch are 2 brass postsattached to a piece of rubber with the bulb in the middle. the rubber justs unplugs from posts and the bulb leads are threded thru 3 holes in the rubber,for each lead, just like miniture christmas bulbs. Just remove the old bulb install the new one threded the same way cut the excess wire and reassemble. Dont forget to clean any corrosion and lube the contacts.Getting it all back together is a little tricky but it can only fit back correctly one way.
Modified by Gerardjg at 5:33 AM 7/8/2006
