Seat heater not working
Covering the 2003-2015 first-gen and 2016+ Titan and Titan XD lineup
jimmyj38
Car: 2012 Nissan Titan Pro 4x
I have a 2012 Titan pro 4x. and the passenger seat heater doe not work at all. The light comes on at the switch, but nothing.
RicerX
Car: '20 Titan Pro4X
Maybe check to see if the connection to the seat (underneath the seat) came loose somehow?
martinbrown44
Car: ford
the same problem i have been facing for 5 days in my titian we are using it for blocked driveway towing nyc, I tried alot of minor things but nothing happened, have you got the solution if so kindly share plz.
carldu
Car: 08 Titan
It could be a fuse problem or a bad switch.
rojoloco
Car: 1993 Nissan 300ZX Twin Turbo (SOLD)
My driver side seat heater (2019 Pro-4X) would cut out after less than a second of being on. Apparently, this is a known issue with the Titan. My dealership looked up the issue and found the problem listed in the database. They had to replace a control box under the seat and the cable leading to it.
Return to “Nissan Titan Forum”
