NickD »
https://forums.nicoclub.com/nickd-u5609.html
Thu Jul 17, 2003 5:17 am
What I mean by rebuild is.......I took the old compressor off, replaces the piston band with the attached shaft, new seals, new bearings, new reed plate. The compressor will vacuum down to about 28.5Hg but when I go to replaced the freon, it will not take any in. If I run a wire directly to the clutch, the clutch engages and seems to work.
And I still can't figure out what the problem is with these seats. HELP!!!!!!!!!
