This happened to me a couple of times in a row a while back. Tech is correct. In my case it was a loose connection on one of the two wires on the positive battery terminal. Check to see if either of these two wires is loose.Q45tech wrote:Each steering/seat has a potentiometer which supplies a location/posotional voltage for each position. When these potentiometers get dirty corroded, gooey, etc the voltage may drop out and the positioner loses its mind [memory].
Do you mean on the battery itself? If so, then we have the cause of this problem and the laboring starter.goody94q45 wrote:
Yeah well I went out this am and took the cables off examined and cleaned. Hooked all back up and no more labored starting kicks over like it did previously.May need a starter later and that would make sense, after all the car is not new, but if the car can wait..................... so can I.bullittandy wrote:
