seat compatibilities
looksLikeA240
Car: break dancing
My s13 seats are complete trash like the seats of many other s13 owners. They are so dookie, it makes me ill having a passenger sit in my car.
So what I was wondering is: What other nissan or any other car compnay factory seats will swap into the s13 and work? For instance, I know many people directly swap s14 seats into an s13. THose are very nice, but around columbus there aren't many good places to find used parts. But I have a friend that owns like 5 sentra ser's and half are junk cars. Maybe ser seats will work? Does anyone know which cars seats will fit into a s13. This would be helpfull to many i think..
thanks,Dustin
Driftntouge
I dont know exactly which ones work except for S14 & S15, and I think R32/33/34 with minimal mods. I dont think the Sentra seats will work, due to the mounting position on the 240s'. The inside rails (toward the console) are actually mounted on the driveshaft hump, and not on the floor, which obviously isnt the case on a FWD Sentra. Hope that helps, good luck.
Mike
R240NA
Driftntouge wrote:I dont know exactly which ones work except for S14 & S15, and I think R32/33/34 with minimal mods. I dont think the Sentra seats will work, due to the mounting position on the 240s'. The inside rails (toward the console) are actually mounted on the driveshaft hump, and not on the floor, which obviously isnt the case on a FWD Sentra. Hope that helps, good luck.
Mike
Nothing else will be a bolt-in other than S13/14/15. The R32/33/34 seats are close and don't require much IIRC.
slw240sx
Car: 1990 Ca18det 240sx Hatch
K car since you re drilled only two holes is it possible with those to redrill the mounting holes allowing the seat to be place so it will slide father back then stock to allow for more leg room ??
R240NA
For aftermarket seats, Corbeau has a nice lineup and are much cheaper than most others, and they offer custom fit brackets for our cars. Sparco doesn't list a bracket, but they can make one if it's ordered, takes a few weeks to get and cost more. Momo doesn't offer a bracket at all.
