robomatic12 »
https://forums.nicoclub.com/robomatic12-u138186.html
Sun Dec 05, 2010 1:20 pm
They don't necessarily have to lock up when you hit the brake, only under certain forces (like a crash). Give them a good tug and see if they lock up. Compare to any other vehicle you have access too.
The seat belt light stays on I'm going to assume? It does not go out when you buckle up? Could be an un-done connector under the seat, could be bad contacts in the seatbelt receiver end.
Doorlocks are most likely unrelated, there is a plastic piece (door cam) that breaks often, it will just let the key turn and turn in the cylinder. Feels like it's not doing anything. Order a new metal replacement one off Z1. You might want to pull the door panel to make sure this is the problem. Follow all the metal linkages.
