dmw98path »
https://forums.nicoclub.com/dmw98path-u78605.html
Wed Jul 30, 2014 7:40 pm
We have a 2008 Rogue, SL AWD with 60k miles. Just over 3 weeks ago, after a long road trip I started hearing a sort of pop/clunk type sound with the drivers side seat belt. A typical scenario where it can occur is when you are driving around a tight corner and the seat belt tightens, then loosens up then tightens up again (pop).
The seat belt stays latched and can not be pulled out but this tighten/loosen cycle of the belt can result in this metal/plastic poping sound as something inside the latching area gives. It can be reproduced by sitting in the drivers seat, seat belt fastened, pulling on the seat belt and then pushing left, across the body then pushing right, away from the body towards the passenger along the same line--to simulate a back and forth or tighten and loosen motion.
Has anyone else experienced this? I'm guessing my only option would be to have the mechanism replaced by the dealer--which since it is a seat belt should be under warranty for life.
Thanks,
-dan
