Seat and Steering wheel repositioning after door closes
DetroitJazzMan
Car: 1994 Infiniti Q45A
2002 Nissan Maxima SE 6spd
1940 Cadillac 62 Series
1953 Cadillac 62 Series
1961 Cadillac
73 Ford Mustang Q code conv
I have what may be a simple problem to resolve. Up until a few days ago my seats and sterring wheel were presented to me just the way i liked it. Today, I have to try to find those aboslutely correct positions without the benefit of technology. Is there a simple fix for this problem??? I've searched and cannot find it. thanks Jazz
Q451990
Start out with the reset procedure in the attached TSB.
Good luck!
Heath
DetroitJazzMan
1961 Cadillac
Q451990 wrote:Start out with the reset procedure in the attached TSB.
Good luck!
Heath
thanks for the link! obviously its not going to be as simple as I thought. I really like that feature, because I wear a leg brace on my right leg and it makes it much easier to get in and out of the car. Best Regards Jazz
fixer
Car: 08 Sentra
does both seat memory led flash, or can the tilt be adjusted at all?, check tsb ITB096-016, you may need a new bcm
DetroitJazzMan
1961 Cadillac
fixer wrote:does both seat memory led flash, or can the tilt be adjusted at all?, check tsb ITB096-016, you may need a new bcm
yesterday I pulled up in the driveway, my neighbor pulled up behind me, turned the key off and left the door open talking to my neighbor. Soon we both heard the steering wheel go up and seat moved. I don't know what happened, but its been working since. thanks for all the help. Jazz
goody90q45
Car: 1992 Infiniti Q45 (sold)
Gremlins. They hopped aboard the ship when the Q came over from Japan and have been with the car ever since.
If you haven't already, blow out the ignition keyhole with compressed air and see if it helps.
