Seat and steering wheel move by itself.
unknown007
Car: White 1993 Q45 (G50)
When I insert my key it twitches then when I remove it it'll do the same.When I hit SET and the number 2 turns off and 1 stays on.Any idea?Maybe the motor or something is out?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
With the "Cancel" button under the column adjust joystick un-pressed, the auto drive positioner will retract and raise the steering column and slide the seat back whenever the key is removed. When you put the key back in it goes back to the last-used ADP setting (1 or 2). To make exit and entry easier.If you press the Cancel button, it disables the ADP system. Unless I'm mistaken, you can't set ADP memory with "Cancel" on either, so that may be the issue with your memory lights.
If the steering wheel still moves properly when using the tilt/telescope joystick dealie, the problem is probably in the slide-resistors that the system uses to detect positioning.
Here's the reset procedure for the ADP system:zerothread?id=289906
I know there is a thread or two floating around with more details on the slide resistors, but I can't find them at the moment. If I do I'll post them up, too.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Heath may have Been the one with the ADP problems, So Berner get in touch with 1990Q45 (Heath).
unknown007
Okay and also it moves apart and apart not closer.Make sense?
shanec86
Car: 86' HR31 Skyline Passage GT, 89' JDM Q45a
unknown007 wrote:Okay and also it moves apart and apart not closer.Make sense?
i was playing with mine and it used to do the same thing untill i just set it to cancel as i found it annoying always moving, although every time it would set itself, it would keep going further and further back. If thats what you mean unknown007
Q45tech
Failure to maintain [clean] the real time position sensors [2 potentiometers] frequently. These sensors send a voltage representing positions to seat ecu which is stored in 3 memories.
Just like a seat number bed matress positions 1&2.
unknown007
That's what I meant shane but mine sometimes gets the seat closer and sterring wheel higher or the opposite.
Q45tech where can I find the sensor?Am I able to clean them too?I never knew about the sensors so my guess is previous never cleaned it.
Q45tech
FSM BF91...................there are 71 pages to read under automatic drive positioner.
unknown007
Thanks will get on it.
goody90q45
Car: 1992 Infiniti Q45 (sold)
Start with the easy stuff and blow out the ignition keyhole with compressed air. You'll be surprised how much dust and dirt will come out of that little opening. If you feel like getting bruised ribs take the 4 piece steering column shroud off and blow the column down also. The FSM should tell you where the position sensors are.
My experience with my first 90Q was that a worn out key will cause the system to work sporadically. Are the edges of your key rounded? Did you do the reset procedure that was posted? Any changes?
Try the air in the keyhole first and see if it doesn't help.
unknown007
all edges rounded off and i have blown air in it but little dust came out and hasn't fixed anything.I havent got to it cause it was like very hott outside so I stayed inside.
ThatsMyQ2Go
Car: 94 Q45 Pioneer AVH-P4400BH Head Unit, MMATS Pro Audio Pro 4.0 Components, Pioneer TS-A6964R 6x9's, JL Audio Slash 300/4, 2 12" Kicker CVR's, Kicker 750.1
How square is a brand new key? I was tinkering with my ADP and it seems to work sporadically, though all of the individual motors except the headrest height all work when done manually
Q451990
If your key turns the cylinder, it's fine. I think the trigger for the ADP is just when it's inserted it grounds something.
There are two slide potentiometers (think sliding volume control on a radio) under the steering column. They're no fun to get to, but if you can clean them with some electrical contact cleaner - everything works much better. If the feedback from these switches is interupted (think crackly volume control on the radio) then the control unit looses track of the position of the wheel and just shuts down.
Heath
