85 720 wrote:We're on the same boat. Up until the tire sizes since you have 2wd and I have 4wd.
But anyways, rims from the D21s and up to 04 Frontiers will fit your truck. I've heard that you can even fit Escalade rims on the 720s but don't quote that from me.
Our bolt pattern is 6X139.7 and our center bore is 100.0. Only the 99-04 Frontiers & Pathfinders, all year Xterras, and Pathfinder Armadas have our rim style so if you can manage to find used rims or something at the junkyard you're in luck. Most of the rims on those trucks are 14 or 15s.
Also, American Racing has the rims that will fit the 720s. But I'm not sure how much you want to spend. They're around $200 a rim.
For 4x4 wheels I've always liked the Cragar Soft 8 wheels in black. they're a good looking steel wheel. 47.95 each at summit racing.
If you've got a bit more to spend the Rota Grid comes in a 720 friendly size. $600-700 for a set of 16x8
And if you've got tons of cash to burn Nismo Volk TE37x wheels are what the Rota Grid is copying. They're about $600 a wheel.
