importmyth01 »
https://forums.nicoclub.com/importmyth01-u25892.html
Fri Jan 25, 2008 11:32 am
Ok just traded my car for a supposidly has a S14 Notch top swap, 550's, S15 Turbo, and bolt ons. I have searched for the past few days and have still not come up with SOLID answers to my questions.
Is there any way to tell the difference physically in the S14 and S15 motors? I know there really is no difference but it may answer the next question.
FYI The block code I could see reads 4490107
Is there anyway to tell the difference in the s14 and s15 turbo ON the car?I cant read the plate on top but the housing says 270955W I believe.
I know the s15 motor has the 6 speed and this car is a 5 speed but I did read the s15 motor will bolt up to the 5 speed.
Also looks as if the oil pan or front main seal is leaking, I need part numbers for:
Front Main Seal and Intake Manifold Gasket
Thank you in advance I would just like to start with thses because if this is a stock s14 swap then I need to go into checking everyhting else on the car...ecu, injectors, rear diff, etc. Thanks again
