float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Feb 15, 2005 9:11 am
I think that turbo wouldn't be real hot on the CA unless you want big power and if you're going to do that, get a t3/t4. That .86 AR on the turbine side is going to equal lag on our little CA. I personally wouldn't use anything bigger than a .63 on the turbine side of this motor. Ideally, for big power and still some OK low end, I'd have a t3/t4 w/a .48 turbine housing.
