jdm_master_X »
https://forums.nicoclub.com/jdm-master-x-u30964.html
Mon Sep 18, 2006 10:40 am
a lot of people are still split on using the 90mm TB (as am i). there are issues such as rewiring the TPS (which isnt much), bypassing the cold idle lines on the TB, throttle sensitivity (reclocking), and power.
for the record, my plan is around 475-550 WHP to use as a multipurpose car (suspension tuning included, etc.). its going to see way more track time as soon as i get another car, so streetability isn't a major issue for me. i just wanted greater throttle response via TB with a port matched IM (so the flow will be more optimal than stock). and i plan to do all of this when i have the parts ready for it (i.e. TB, IM, fuel rail, injectors, ECU tune, ignition setup, upgraded turbo), but for now, i just want to gather up the parts i would need before i step it up. i just want a more responsive throttle with a larger capacity for air. i already have an HKS F-Con coming in soon, and injectors should be coming up shortly.)
im just so undecided because i got both of these for a great price, complete, and in excellent condition. and to date nobody can give me any sort of comparisson with the N15 TB (Tomei) or the 90mm TB. i sat down with my S13 TB and the Q45 TB and i compared. besides the size and linkages (all the obvious things), the q45 seems to open at 100% true WOT, while the S13 TB just comes short (the Q45 butterfly opens up to 90 degrees, while th S13 TB is just about 80 degrees.) i dont know how much of a difference that makes, but i guess ultimately its prefference.
from your experience, tony, how do you rate the Tomei TB?
