808customz »
https://forums.nicoclub.com/808customz-u71953.html
Mon Mar 10, 2008 2:14 pm
i have a redtop sr20det and i cant quite find the answers. First of all, i will be changing the waterpump, etc. a basic rebuild. where can i find a FSM for the sr20?, download or buy a manual. i will be upgrading to a gt28r and from what i read it will fit on the stock exhaust mani. how much psi can run safely without changing injectors, MAFs. etc? basically all i will be doing is using a FMIC, stock motor, ecu and just upgrading the turbo, using the stock tunning, therefore no need for dyno.7-9 PSI? with that is it then necessary to get a wideband and sfac etc? or should i get one just because it will do the motor well in the long run and do a proper dyno tune? for everyone, sorry for such noob questions. I, like everyone else, did not know everything and needed help at one point. thanks in advence
