searched, cant find. Where to buy Studs!
BuLLeTdrift
Car: 91 240sx fast baq
Maybe its that i've been up to0 long searching for other parts and i'm hella tired, but where the hell can i find a place to buy intake manifold studs and turbo studs? Intake studs(self explanatory), but for the turbo I need the studs that go from the turbo to the dump pipe/ down pipe/exhaust side of things. Mine has 2 on there and i just realized "hey i need 3 more". So yea and help would be grrreat. thanx.
Hijacker
Car: '92 240sx Convertible
'94 F-150
actually. you need 3 bolts. not 5 studs. SRs use 2 studs to help set the extension in place and then you bolt it in with 3 more bolts.
The bolts should be identical to the Twin Turbo Z bolts, so order some for a Z32TT.
For intake studs, you need 2. The rest are bolts. You should be able to call up Nissan and order a set for a '92 SE-R
BuLLeTdrift
tenkawa_akito wrote:actually. you need 3 bolts. not 5 studs. SRs use 2 studs to help set the extension in place and then you bolt it in with 3 more bolts.
Well that explains it all to0 well. Yea i was wondering why I only had two studs on the mani and two on the turbo lol. damn i have a long way to go, thanx for the reply bro.
