PapaBurgundy »
https://forums.nicoclub.com/papaburgundy-u84105.html
Tue Apr 21, 2009 1:44 pm
Alright thanks float! My car was running great then it just killed on me and hasnt started since. I noticed it was throwing code 34 and I realized I didnt have a knock sensor. I read on here it pulls timing after a while of not having one, makes sense because when it died it acted just like when the CAS plug falls off. So I'm supposed to run a sheilded wire from the sensor to pin 23 on the ecu and the sensor grounds itself on the block correct? I also read about temp sensor failure shutting the engine down, anyone want to shed some light on that?
