searched and nothing, blinkers and reverse lights dont work
fleali88
Car: 97 240sx, s14 sr20det swap in the works
Its a 1997 240sx se, and currently there is no cd player installed, the person i got the car from said that the blinkers and reverse lights are wired through the cd player, and i'll need one for them to work, is this true?. i cant find anything on it anywhere.
ward28465
Car: 95 240sx blacktop SR
No. your blinkers/ reverse lights are on the same circuit. get a 240 mannal from a parts store, a multi-meter and start chasing wires.
teamelude
Car: 1993 240sx Nissan
Did you check the fuses? And if not that I know on most cars if the hazard switch is out the blinkers wont work you could try having a proven to work hazard switch and borrow it and see if it works.
