niconoob »
https://forums.nicoclub.com/niconoob-u69652.html
Mon Jul 02, 2007 12:16 am
Hey guys, It's like 3 in the AM on the west coast and I've been working on my car ALL DAY, and I'm very frustrated. I'm gonna work on it all day tomorrow too before I have to put it off for another week. I should've sent the harnesses away to get done!
So I've already installed my engine w/all accessories, trans, starter, drive shaft, exhaust, a/c w/tig welded ka/sr spliced lines, re-fitted the heater core hoses, and a few other random things...(see my fmic install Q lol)
But it's REALLY hard to find complete wiring info, as it is readily available for s13 sr into s13 & s14 chassis.
Through the searching I've found out the info for wiring the ka m63 plug to the sr f4 plug, so I don't thinkthat will be a problem.
I also know that I have to extend the maf plug and o2 plug (&power steering?), but both ends of the o2 connector are on the sensor so I can't figure out where it wires into the harness to extend from. Similar issue for the maf sensor, it won't plug in anywhere on the harness. There are 3 fairly thick loose wires poking out of the harness right behind the valve cover (O2?) If I remember right, they were white, black & black).
I also heard that I have to do something with the plugs by/at the fuse box, splice in the ecu & fuel pump relays by the ecu, and windshield wiper motor & amplifier. Anything else I'm not aware of aswell. I still have the battery/fuse box part of the ka harness in the car, and I assume this has to be removed also.
Thank you in advance
