nzmoman »
https://forums.nicoclub.com/nzmoman-u41093.html
Sat Jun 03, 2006 7:21 am
yup Warped is right, get your rear main seal replaced and check your transmission and differential seals (if you're replacing that). You normally dont have to change valve gaskets, spark plug seals, oil pan gaskets etc, but if you want you could do those. Most of these things will look really new on a good motor and will seem like you're throwing away good parts, but you will also get a chance to know your motor. Check your hoses too! Good Luck
The main rule of thumb is that if it will be a pain to get to in the engine bay, do it now.
