Seam welding
paul_s13
Has anyone done this, and if anyone has how long did it take?
Jezz_s13
Car: Sil80 Track Car
I reckon it'll take fecking ages. SKIDS did his S14 didn't he?
I'm going to do a bit inside my car (before the floorpan falls out)and around where the top wing beam thing joins to the A-pillar.
Projex240
Car: Dogs , My RIDE
stillen does all of their 300zx tt's with it--id imagine, it would involve alot of time, and removing of interior peices. LOTS of work.
nextlevel
A frind is about to do it, its a pain to prep it though, removing interor panels isnt hard, but removing the sound deading material takes a while then removing the caulking takes a while. I plan on doing it eventually, as my car is already stripped most of the wok is done
Dystopia
Car: Nissan S13
with the s chassis there is a lot of adhesive you have to have remove or it wont be as stiff definately worth it takes time.
paul_s13
Sod it, i can't be bothered! Its definitly going to be a drift car so I don't have to make it road worthy, going to weld the diff up too! :ylsuper
nextlevel
DON'T run welded diff on street, eventually weld will break from stress and say goodbye to your diff
paul_s13
I might not weld the diff but the car is going to be trailered everywhere anyway.
nextlevel
for track use it may be ok, atleast if it blows up on you there you wont be stranded, if you have the extra $$$ I would just get a really agressive 2 way
paul_s13
nextlevel wrote:for track use it may be ok, atleast if it blows up on you there you wont be stranded, if you have the extra $$$ I would just get a really agressive 2 way
Nope, i'm not planning on spending much money at all on this car, the most expesive thing I will buy is an oil cooler and not much more.
nab911
Car: 93 Nissan 240SX SE
I still have an oil cooler to hook up but i think its a worthwhile investment... will save your motor after some abuse :)
