Seam welding a S13 with epoxy?
Surewin
Car: 90 240SX
Any opinions about using an epoxy, like the one in the link below, to bond the chassis seams together? Essentially seam welding with epoxy.
http://www.3m.com/Product/info....html
Other ideas I have been thinking about: soldering & brazing. Comments?
180fan
Car: 89 fastback
it's just metal glue. not for structural parts
HashiriyaS14
Car: '95 Nissan 240SX
'08 Honda Accord
'08 Honda NPS50
'03 Kawasaki Ninja 250
'60 Honda Super Cub
Yeah, straight from the link that you provided:
"Two-part epoxy used to bond steel, aluminum, SMC and FRP. For use on outer body panels only, not on structural components. (Automotive Aftermarket Division)"
If you're going to seam-weld, just seam-weld.
Not that I know that much about it, although I would like to do it to my car once I get enough downtime to strip it down to the frame and do a fresh repaint. I'm not sure of the benefits of seam vs. spot vs. stitch welding.
Surewin
Car: 90 240SX
OK, point taken. How about this epoxy...
http://automotive.henkel.com/P...Id=17
Quote » This product is also used to stabilize spot welds and increase vehicle rigidity. [/quote]
skylndrftr
Car: 07 Nissan Versa S
2010 Ariel Atom (pending...)
http://solutions.3m.com/wps/po...ndler aerospace adhesive
search around 3m they have just about everything you could need. Might be better off wit hthe welding though you can grind away weld this stuff is pretty damn permanent
