Seafoaming
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Has anyone ever seafoamed their motor? How would one go about doing it?
oki_bum
Car: SR Powered 1990 240SX
i did mine. seemed to run smoother after.
how to:http://www.diyimports.com/seafoamprint.html
redtop91
Exactly what I needed to know. Thank you very very much.
notslow
Car: Nissan Sileighty
found out the hard way that it is not the smartest thing to do in a parking stall at an apartment complex hahaha. Definitely ran cleaner after though.
redtop91
When it says crankcase does it mean directly into the valve cover where you pour the oil?
Tulsa_S-13
Car: 1991 SR 240sx
Yea I seafoamed the ole KA a couple of times, and it did seem to run smoother afterwards (Well, about as smooth as a KA can be )
Use the brake booster vacuum line to get it into the intake and be sure that if you do seafoam your crankcase to hardly drive the car that way. And yes, pour it directly into the valve cover where you would normally put oil.
Also, is your SR still knocking?
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
When doing the oil, change it about 20 minutes after adding it because it thins out the oil alot. You can also you seafoam to find exhaust leaks pretty easy.
Logan76
Car: Junk
dude, I gave you an in-depth report of how to Seafoam, I E-mailed you it...gosh!
vutony
i heard your only suppose to do it on NA cars and do it a few days before the oil change cuz it eats it up
iono??
Logan76
Car: Junk
IVe done it on turbo cars, and N/A cars, You should do it Directly before oil change, pour it in, and let your car idle 5-10 minutes, NO LOAD, its known to thin oil out, ALOT, Dont take that risk, If put in your crank case, let her idle for a bit, then drain that old oil, and change it with new oil and a new filter.
Loki
Car: 1994 Nissan 240SX Convertible
2010 Toyota FJ Cruiser
2001 Ford F-150 SVT Lightning
Oooh, fun. I should do this in the next month or so when it gets near the oil change time.
redtop91
ROFLES! I didn't let it idle. Will the oil thicken back up? I don't have any money to buy replacement oil.
efrain240sx
Car: 1992 nissan 240sx HB
my automatic trans teacher showed me another way of doing a poor mans engine flush. What you do is you get a quart ATF fluid and you add it to the engine, and you let the car idle for about 15 minutes, then you do a oil change. It really works I tried it on the old KA and on the SR, after I did it to the KA I looked at the oil that came out and saw some sludge that must been stuck inside the engine.
Logan76
Car: Junk
No the oil wont thicken back up, I E-mailed you awesome directions, Ryon, I would seriously change your oil ASAP if you put a bottle of seafoam in your motor and have just been driving it...
redtop91
redtop91 wrote:I don't have any money to buy replacement oil.
Logan76
Car: Junk
dude, unless your running syntech, you can get it for like 3$ a quart + a filter...you need to get the money, or park the 240.
