seafoaming it up on saturday, gots some questions
putang29
Car: semi-sold 90 300zx n/a
2007 chevy avalanche
1990 infiniti m30 w/ rb20det
1995 240sx kouki w/ rb25det
firstly, yes I have read the thread by AZhitman.
My main thing is that I have 650 miles on a royal purple 5w30 oil change, and after I run the seafoam, would it be needed immediately afterward that I change the oil + filter again? Or just wait until im due for the next change to run seafoam.
If any1 has pics of the hoses AZhitman talks about sipping to seafoam into and which ones to avoid, I would appreciate it if you could post them for me.
Also, would it be worth it to pull the oilpan off if I did change oil and clean out the filter and pretty much everything I can while its off?
Thanks again.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
wait untill you are ready for your oil change, this stuff thins your oil to help clean things internally, you do NOT want thsi stuff in your engine for a long period fo time
fwiw don't expect any noticible changes in the car, it just cleans it's not majic
GerryO
Car: 1993 J30t
Pearl White
Black Interior
Possibly more fun, safer, more effective and better in the long run to:
- replace both PCV valves
- install new spark plugs
- remove and thoroughly clean EGR tubes
- clean throttle bodies and MAF
- remove and clean the IAC/AAC valves and Air Regulator
http://home.swipnet.se/e-solutions/IdleTech.html
http://home.swipnet.se/e-solutions/IdleTech2.html
Pulling the plenum works too!
