loystock »
https://forums.nicoclub.com/loystock-u10145.html
Fri Feb 05, 2010 9:34 pm
Result of Seafoam usage is mixed. If I were you, I would use either BG44K (@ $18) or Red Line SI-1 (@ $8) Fuel System Cleaner. I've been a long time user of BG44K but switched to Red Line last year after BG44K formulation was changed.
If you are handy with tools, you can do all of the jobs yourself and we can help you. You can buy the Transmission Service kit and drive belts from IoS (infiniti of Scottsdale) - infinitipartsUSA.com a.k.a "everythinginfiniti.com."
Your car requires Nissan Matic-D fluid but Dexron III and the latest Dexron VI can be used.
And Mark's right, stay away from that mechanic as he can do more damage to your car.
