SEAFOAM??????
Loofee95SE
Car: u gota sister??
Any of u guys done Seafoam on your CA?? I'm pretty curious about it...heard tons of good stuff about it.. alternate cleaning solution to taking the head off?? suggestion please. thanks C
originalsin
worked wonders on my friends honduh, def notice a diff in throttle response and he says he has noticed a bit better gas mileage, i dunt se any reason why it wouldent be safe on the ca
NeedCAforS13
Car: CA swapped S13 coupe
not sure if its designed for use with turbo motors... I've heard good things about it though, and would be interested in using it on my CA as well
Sean
rico05
Car: 1992 RMS13 w/ CA18DET
I used it. Motor was clean enough to take 2 whole cans and barely smoke at all
Nunook
did u put it in the vacuum connection at the back of the intake for the brake booster?
originalsin
ya thats where it goes, u can put some in the oil also, but then u have to do an oil change after a little bit of driving because it thins out the oil
Fenvy
Car: 2005 350Z Base 6MT
done it on my b18b1, ka24de, sr20det
it's fine
and you should not try after put it in oil, just let it idle for 10 min and dump it
