mac, And some of these motors like my v6 that have two throttle butterflys and the brake-booster vacuum takeoff is ONLY the drivers "bank" and so the SeaFoam really won't 'hit' the cyl's/valves much at all on the pass. side rt. "bank". And I suppose this could possibly happen if ONE throttle feeds a very 'split' intake where the Br. booster is taken off an extreme plenum far to the driver's side where you STILL have to find a "vacuum TAP" closer to the pass. side to clean "proper" that side's cyl.'s/valves ??
Is why SOME try to "inject" the stuff directly @ the throttle(s) - thus getting a R. & L. banks cleaning.
Remember - you want to maximize the distribution of the spray to all "runners" as much as possible , may utilize multiple points of "injection" to achieve.
Knowing ALL points to tap vacuum helps.
