jmw19_99 »
https://forums.nicoclub.com/jmw19-99-u30795.html
Wed Aug 10, 2005 10:28 am
If ur using it in the oil, let it run at idle for 10 minutes then shut the car down. Drain oil, change filter, add new oil. Done. If ur using it in ur intake, u have to hold the rpm up just to keep it running while it is being applied. Then, when all the seafoam is in the intake, shut the car down and let it sit for 10 min. Restart and run at 2000-2500 rpm for five min, then let it idle for five min (this is where you get all that wonderful smoke!!!) If using it in the gas, treat it like any other fuel injector cleaner, just pour and go. I do not recommend using more than 1/2 a can though in the take and 1/2 a can in the oil. Use 3/4 in the intake. Hope that helped and have fun!!!! 1
