seafoam evap test?
towncarblue
Car: 2002 Nissan Pathfinder
i have a 2002 nissan pathfinder with a check engine code of P1456 [ small leak detected].
i wanted to know if using seafoam would show where the leak might be"?
has anybody tried this
No, Seafoam is not a leak detector.
Replace your gas cap FIRST. Common problem.
Next most likely: The evap canister @ left rear of the vehicle. Typically a leak there OR the bypass valve and solenoid next to the canister. Have the system tested with an evap tester to find the source of the leak (dealer or local shop can do this).
