Seafoam: Brake Booster Hose?
Backfire
Car: 2008 Altima Coupe
Hello all,
Haven't really posted to much in the Altima forum before. I wanted to do the Seamfoam in my girls 08 altima coupe. I already dumped a 1/3 in the gas tank and filled up. The 2nd 1/3 is supposed to go in a brake booster hose. It says on the back of the bottle to use a brake booster hose far enough back to let the seafoam get to all cyclinders. Does anyone have a picture of which hose to use?
Thank You,
Warped161
Car: 90 s13 the never ending project
its the rubber hose going to the brake booster, you disconnect the hose from the booster and use the vacuum pressure to pull the seafoam into the motor. as the seafoam goes in the engines idle will climb, use a steady amount as too much will stall the motor. which you dont do till your all done.
Backfire
Thank You for your help!
