I don't think chevron is any different from other high quality gasolineJacko3 wrote:Toolboothwilley:
How is the little bundle of joy doing? Yep, if you ain't using Chevron gas everyday, then Lucas Injector cleaner every now and then, is okay.
exactly i get that clunk/ hard shift.kmckis1029 wrote:after putting my grounding kit in when im in auto everything is smooth even under WOT... but in manual mode 3rd gear (about 6000rpm) does come in with a "clunk" or hard... but dosent slip at all...
So i should get that checked out? my car has 25k miles and is a 05 g35x... maybe just old fluid? i brought it with 18k so i know the car was sitting before i brought it.
Yes. I think all of the kits on the market (including mine) allow for the engine cover to be replaced.G’d up wrote:
do they make a grounding kit that allows for the engine shroud to be put back on?
I was fairly skeptical of Seafoam for years. Then I ran into a misfire problem on my mom's van. I suspected the ignition first so I replaced the plugs, wires and distributor cap and rotor. Problem persisted. No biggie, those were probably nearing the end of their life anyways. After some poking around, I speculated it was a fuel deliver problem. The issue with chevy vans is they use these odd poppet valves at the end of long tubes to deliver fuel to the ports. There is a single injector that feeds all 8 lines to the motor. They have to run with a minimum amount of pressure in order for the poppets to operate. As these are embedded into the manifold (its a van so getting it off is a pain). For the cost of a couple bottles of seafoam, it was worth a shot. Dumped 2 bottles in along with fresh gas and 20 minutes later, the misfire was gone. How does it work? Beats me. Did it save me the headache of removing the upper manifold? Absolutely.SteveTheTech wrote:There are so many useless products on the market, fluid wise.
If he says its normal and isn't worried about it at all, make sure you put on a grounding kit. I think it will help every shift in your car. I can't even remember waht it was like to drive my car without the grounding kit but I do know that I don't ever want to drive it like that again.kmckis1029 wrote:called nalley infiniti of marietta, ga and he told me that the hard 3rd gear shift could be the "gear locking" ... thats what it sure feels like as 3rd gear dosent slip one bit... and its the only gear that dose that... but he said he is willing to take a test drive with me to make sure... so ill drop by there next week before the holiday.
Hey C-Kwik...have you ever tried using the Seafoam in the vacuum lines to eliminate carbon build up?C-Kwik wrote:
