Se to Se-r
Rookie_ca18
Car: women, sleep, cars
i just wanted to know how difficult it would be to put a sr20de motor from a 96 se-r into a 95-97 200sx SE, basically if it would be strait foward or would we need new mounts and things of that sort. thanks for any and all responses.
nametakennow
Car: '06 MINI Cooper S
It should be pretty straight forward. Since you have the engine out, it'd probably be best to get aftermarket mounts while you're at it, and besides that a lot safer (just in case) to at least get SR mounts. I would think the mounts would be the same, but you never know. Where's NISTECH? He knows this stuff most of the time.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
How bout new mounts, cross member, transmission, motor, wiring harness, ecu, etc.... very expensive swap, very!!!
Rookie_ca18
Ok um... maybe i was too vague with this question. This it what my friend has a 96 se-r the whole car, he can get a SE shell, but would there be a problem putting everything from the se-r into the SE? Like Red_Det stated, would the harness have to modified in any way, and so on. Thanks for your responses :)
RED_DET
Vendor
2011 Infiniti G37x
Wouldn't think so, just swap everything over. SE chasis same as SE-R.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Rookie_ca18 wrote:Ok um... maybe i was too vague with this question. This it what my friend has a 96 se-r the whole car, he can get a SE shell, but would there be a problem putting everything from the se-r into the SE? Like Red_Det stated, would the harness have to modified in any way, and so on. Thanks for your responses :)
A friend of mine did that with a classic sentra. He basically turned his Sentra E into an SE-R, minus the SR20DE. (He had full bolt-ons on the GA16DE, which made it still quicker than a stock SE-R).
However, there were a LOT of suspension differences. I think the power steering pump might have been different too.
Anyway, if you want, his email is [email protected]
Tell him Torry gave you his email, and you had questions about converting an SE into an SE-R, and what all is needed.
Rookie_ca18
Hey thanks torry and red_det
