Kouks wrote:OF course it will fit. Shock spring strut design is identical. The differences rely on the differences in dampening in the shock/strut and the height/spring rate differences between the 4 cyl. and v6 models.
I cannot tell you what it will do to the ride height and what the spring rate difference is. If you can find the differences in weight between the 4 cyl and v6 models up front, you can figure out how much it will affect it.
My problem is the 3rd gen. models. I have acquired a se-r suspension for really cheap(50 bucks for all 4) with less than 5k miles on them. I would like to at least put the shocks/struts on my car which are built more for higher spring rates and travel of a lowering spring than a stock 2.5 shock. I cannot find the spring rate for the se-r altima, and the weight difference between the two motors. Any help?
Thanks for the info! I am planning to do exactly what you are trying to do - use the struts/shocks from the V6 and use lowering springs for the 4cyl. I was actually going to try and get the full strut/shock and spring setup from the 3.5SE so I could have the sportier suspension without lowering the car (making a 2.5SE model, if you will), but I found a deal on an Eibach Prokit for the 2.5. So now I am looking to get just the struts and shocks for the 3.5SE.
Since you've acquired the SE-R suspension, it would be easier to get the information yourself. First measure the ride height you have now, then again after the install of the SE-R setup. Compare the two to get the difference, if any. Then you could decide if swapping the springs is beneficial or not. Of course, you could then post/share your findings here
