Yes that would definately be the case then. Sometimes its a PITA to get it to line up. Shine a light on it so you can see how it lines up. Sometimes it will come unhooked from the back of the cluster as well. But you will have to unhook it from the transmission to be able to pull the cluster all the way out to check.Caplax40 wrote:Oh no it doesn't work. All the cleaning did was make it so that it just twitches between 0-5mph but doesn't go past the 5mph line. So my speed is always a twitchy 5mph.
I did talk to a guy and he said that there's a tab of some sort that needs to be lined up and that it's probably not in all the way. I'll check it later tonight.
