SE ALARM??
240sxdominos
Car: 1990 fastback
I dont know if 240s ever came stock with an alarm but mine has one. Now that I have my SR, whenever I drive my car the alarm is always going off. It doesnt honk it just blinks the lights and sounds like I have my turn signal on, but when my headlights are on my lights stop blinking but the clicking noise of the lights keeps going on in my car, and theres also a little red light on the steering column that blinks too. I was just wondering if anyone knows how to disonnect this stupid thing so i can drive in peace. I drive a 93 coupe se. -John
double_jd13
Car: 96 240 w/s13redtop
it sounds like it could be aftermarket, just that the siren is not connected. see if you can find a button or toggle switch under the dash. then turn your key to the ignition on position and push the button or fip the toggle switch. hopefully the light on the column turns solid and its in valet mode. that aleast should keep it from flashing the lights, till you can find the brain and disconnect it.
jason
240sxdominos
Car: 1990 fastback
i remember having the dash off and i saw a little black box with a little switch on it, i thought it was for the cd player or something but i now think it might be the alarm, ill check it out.thanks
Dedlyvirus
Car: 1991 Nissan 240sx SE
i have the same problem, but i cant find a switch on my 240, what did you do with yours
