ABS, VDC Off, and SLIP lights
mernyfont
Car: 2004 M45 Premium Package B, twilight blue, gray leather [<70,000 miles]
Hi all - just checking to see if this is a common light combo and any likely culprits.
Thanks.
mernyfont
And would you say, Dealership or a Midas-type place?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If you mean the SRS light then it would be a weird combination, you might have something going out in the steering column or spiral cable. If you mean ABS or brake, then it might be as simple as low brake fluid. If you mean a steering light then it may be a steering angle sensor going out. Post a pic and get the codes for the brake and chassis systems read.
VStar650CL
Technical Expert
mernyfont wrote:
Tue May 25, 2021 10:15 am
Most decent repair shops will have something like a SnapOn Solus that can read all the onboard systems. Dealer probably isn't necessary.
VStar650CL
Technical Expert
I see the title change, check your brake fluid. If it's below halfway to the "MIN" line it will often trip the lights on a bump or hard turn. If it's low because of worn pads, replace them.
mernyfont
Thanks - I'll check the fluid level and pads, at a brake shop :)
JOHNQ
Car: 99Qt
02 Q
03 M
mernyfont wrote:
Tue May 25, 2021 12:37 pm
I fixed my 3 warning lights by replacing both front ABS sensors on my 03M45
