SDS Gods i have a Question
BACARDI_DWB
I am working on a plenium design right now for the JDM head (8 port) and i am thinking about using an injector for each port and since i am planning on using the SDS how possible do you think it would be to make 8 injectors work on a SDS EM4. btw going to be using the DIS-2.
Thanks guys
Dee kinda want to hear from ya on this one.
BACARDI_DWB
I am thinking that if you wire in parallel for each injector "set" i should be fine. i would just worry about the loss in voltage. and instead of using one 800cc injector i would use two 400cc injectors wired in parallel. comments?
boost_boy
BACARDI_DWB wrote:I am working on a plenium design right now for the JDM head (8 port) and i am thinking about using an injector for each port and since i am planning on using the SDS how possible do you think it would be to make 8 injectors work on a SDS EM4. btw going to be using the DIS-2.
Thanks guys
Hmm, you like trouble, don't you ? I wouldn't screw with it simply because the gains is not worth the amount of work. Go with your original plan of using 1000cc injectors and you'll have enough fuel on tap for over or around 700whp. You don't want to over fuel the poor little engine now, do ya'?
Dee
BACARDI_DWB
well the reason i wanted to use a set of 8 vice 4 is cause i wanted an injector per port. running eight ~450cc injectors would be fine. but i can make it work the other way too. simple is key i guess. i am one to over complicate things.. Thanks Dee
BACARDI_DWB
BUT if one was to wire each "set" in parrallel do you think it would work? also dee i will be emailing you about a boost controller set up that you should hear how i am going to be setting it up. VERY intereresting. load based boost which is VERY responsive and true in comparison to other boost controllers. stay tuned
Bwana
Car: Denali
Somehow I think that the parallel injector wiring would work. You could run separate dedicated positive wires and just tie the neg wires together... maybe?
I want to hear about your b/c setup too...
float_6969
You're making it way to complicated. SDS has what they call an EIC, Extra Injector Controller. http://sdsefi.com/eic.html
BACARDI_DWB
float you are my hero.
Bwana, you will have to stand by, really can't say much as of yet. my electronics guy is working out a prototype right now and we will see if it works and market it. I am VERY eager to see how it goes. Load based boost almost gives me a chubby.
float_6969
Is it like this?
Bwana
Car: Denali
Ryan fails at hotlinking.... Keeps me busy just cleaning up after him.
float_6969
I know where you live buddy.....
What did I do that needed fixed?
Bwana
Car: Denali
You had a ] bracket where you needed a = after the first [url. Just look at the quote!
