Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
Postby
sashki2 »
https://forums.nicoclub.com/sashki2-u166415.htmlFri Aug 20, 2010 12:52 pm
My compliments on your photos compositions!
How would you summarize the difference in feel between stock springs and H&R? Have you find rear anti-rool/sway bars anywhere?
Postby
EibachMBZ »
https://forums.nicoclub.com/eibachmbz-u125972.htmlFri Aug 20, 2010 3:01 pm
Hows the camber adjustment with H&R springs installed?
Are you able to adjust them back to factory spec or they will still have more negative camber?
Thanks
Postby
SDMF »
https://forums.nicoclub.com/sdmf-u129241.htmlSat Aug 21, 2010 12:12 am
Thank you all for the compliments!!~~
The H&R springs gave a slightly improvement in cornering, i feel that it sticks better to the road. It rides stiffer than stock, and I noticed that the slap over road bumps was more pronounced. Not terribly so, but still retained a decent ride quality.
It also has a more aggressive look. It lowered the car slightly more then an inch in my case which was just perfect for me.
The alignment was out to lunch, esp toe, but they managed to adjust it within spec. Camber is within spec but still neagtive.
Postby
EibachMBZ »
https://forums.nicoclub.com/eibachmbz-u125972.htmlSat Aug 21, 2010 1:44 am
Cool!
I am about to order my H&R springs and my major concern is the camber and toe adjustment.
Since I will also be running 20's soon and tires cost alot, I wanted to make sure I am able to adjust my camber and toe within OE spec.
Thanks for the info! Great looking car and our EX look kind of like twins specially with your painted stock wheels.
Postby
sashki2 »
https://forums.nicoclub.com/sashki2-u166415.htmlThu Aug 26, 2010 1:07 pm
SDMF wrote:Thank you all for the compliments!!~~
I'll most likely do H&R springs after my home improvement project completed.
...And I want this aero kit so bad. Does it work if you have those sonic sensors? Another concern I have is that my hitch will interfer with the rear bumper spoiler/lip - does the lip make bumper any lower?
SDMF, do you by chance have part numbers for your kit?
