MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Sat Feb 09, 2008 12:44 am
Keep in mind that there are two separate standards for 2GB+ SD cards.There's the original SD, then there's the new high capacity SDHC. If you try to use an SDHC card in a device that only supports HD, it won't work properly (or at all, most likely). That may be the issue with your PC reader...the reader probably knows there's SOMETHING there, but can't read it because of the different standards.
Does your card look like this:
or this?
