Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Thu Feb 17, 2005 1:42 pm
its the distance between the centerline of the tire/wheel (determined by offset, width, spindles design..) and the intersection of the line drawn by the kingping inclination (determined by other factors such as suspension design, type, steerling linkage desnign, etc) and the ground.
theoretically, if you had zero scrub radious the force on the steering adis would be nil, enabling you to not need power steering and reducing the force input back to the hub, etc to a minimum.
there are a few ways to reduce the scrub radious-increase kingpin inclination (this assumes a positive scruib radious)...this isnt a good option because you want to keep it between 9 and 14 degrees IIRC for steering geometry issues.-Use a more positive offset wheel (bleh....theres dissadvantages to this to, and clearance issues)-reduce how far the spindle sitst the hub assembly outboard (yeah..good luck with that)
See..now you know why you want to keep your offsets and wheel widths (in 1337 JDM drifter speak) "wussy" or (in educated peoples opinions) 'propper' or close to factory spec as possible while still maintaing the advantages of wider/lower spect ratio tires (better turn in, greater cornering force at a given slip angle...stickier compounds).
I'll try and dig up an illustration sometime if you're still confused later, after I finish moving and reading my GMAT prep stuff...-Chet
