Drift »
https://forums.nicoclub.com/drift-u3827.html
Thu Oct 02, 2003 5:56 am
Hi, I messed up my ignition timing. I pulled out my distributor rotated the shaft and now the car wont start. Per FSM I rotated the crank pulley to the orange mark 2nd one from the left (others are white) the 0 TDC mark. Pulled out my distributor lined up the dot on the rotating part w/ the groove in the shaft, I even pulled off the cap to make sure that it was pointing to the number one plug. Attempt to start the car and it just turns over, no start. I've done this process several times to make sure I have the timing correct. The car start before I pulled it out the first time btw. I also check spark and fuel, both seem to be okay. Am I missing something, maybe I'm doing something wrong w/ the timing adjustment? Does anyone know what it is? I'm tired of driving my gf's jeep. =(
